i-doit Add-ons
Unlock limitless potential of i-doit: Expand with powerful Add-ons, advanced features, and seamless integrations
QR codes make it possible
With i-doit it is possible to create a QR code for each object. This can be attached directly to the relevant device or room with a label. The practical thing is that almost every modern smartphone can read these QR codes with the appropriate app. Connecting your smartphone to your i-doit CMDB is therefore child's play. You have your i-doit in your hand at all times, so to speak.
itInventory – i-doit Scanner (mobile Add-on)
The „itInventory“ app from our development partner Georg Sieber allows QR codes from i-doit or self-printed barcodes such as inventory labels to be scanned. The associated object information is retrieved via i-doit's JSON API and displayed in the app. The data can be edited quickly and easily via the app. The app is available in the Google Play Store and the App Store.
Create your own add-on
With the i-doit Add-on Packager you can easily create your own add-ons - without any programming knowledge. Let your functional expert knowledge directly go into i-doit or i-doit cloud and actively shape the range of use of i-doit. Use the Add-on Packager to create an add-on for i-doit oder i-doit cloud from your industry or solution-specific idea.
