i-doit Add-on SM-VIEW Cable
Visualize and analyze your network cabling. With SM-VIEW CABLE you always have the entire IT under control across locations.
Functions
- Connections are documented at wire/fibre level.
- Accurate knowledge about incidents in the system.
- Capacity planning & utilisation displays are visualised.
- Planning of alternative switching paths in case of failure of individual cables.
- CSV imports and creation of individualised reports.
Manufacturer
Description
Is your cabling business-critical? In the event of a fault, CABLE shows you which systems are affected and ensures that operations are quickly restored. In this way, you maintain a full overview at all times and keep your IT growth under control.
Pricing & support
For information on pricing and support options, please visit the manufacturer’s website.
Do you have any questions on this add-on?
If you need more information about this add-on, please send us a message. We will contact you in a timely manner.
